USB to RJ45 Console Cable USG20W-VPN
alehzn
alehzn image  Freshman Member
I would like to use the following cable in order to connect my Windows 11 (x64) to my USG20W-VPN via the (RJ45) console port.
Cisco USB-Konsolenkabel, USB auf Rj45-Konsole für Windows/Vista/Mac/Linux (1,8 m) hellblau USB Light Blue 1.8m/6 Ft : Amazon.de: Computer & Zubehör
To connect, I am using the software called TeraTerm with the following settings:
However, no matter what I do, I simply see the cursor blinking, nothing else. Driver has been installed by Microsoft automatically. I have also tried installing them manually given this page: VCP Drivers - FTDI (ftdichip.com)
In addition, I have used my Mac with the software called Serial, exchanged the cable, in case it would be the root cause but without any luck. What I am doing wrong?
Thank you.
Cheers
