Secuextender SSL con Windows 11 si disconnette
GabrieleBSI
GabrieleBSI Posts: 1 image  Freshman Member
Buongiorno, ho configurato su vari apparati USG dei miei clienti la VPN SSL.
Sui client con S.O. Win7 e Win10 installo il SSL_VPN_Client_4.0.4.0 (per windows7 32bit)  e tutto funziona bene
Con l'arrivo di Windows11 il software si connette, ma se tento Desktop Remoto si disconnette.
Ci sono delle incompatibilità con Windows 11?
Grazie
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 975 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @GabrieleBSI
    Yes,SSL_VPN_Client_4.0.4.0 not support Win11 Now.
    You could kindly use L2TP over IPsec instead of SSLVPN.
    Also,Please be aware of some windows update will affect L2TP.
    https://support.zyxel.eu/hc/en-us/articles/4415084375954
    Kevin
  • Omnia
    Omnia Posts: 60 image  Ally Member
    Ci sono novità?
    Abbiamo anche noi diversi problemi di disconnessioni
  • Asgatlat
    Asgatlat Posts: 121 image  Ally Member
    First Comment Friend Collector Eighth Anniversary
    Hi @GabrieleBSI
    Kevin
    Hi Kevin,
    when SSL VPN Client will be available for Win11 ?
    at the moment my company's computer is set to windows 10 but some employee want to upgrade to win 11
  • Zyxel_Kevin
    Hi @Asgatlat,
    We are testing the compatibility of the VPN Client with win11.
    And we will update the progress ASAP.
    Thanks your patience
    Kevin
  • mMontana
    mMontana Posts: 1,443 image  Guru Member
    No idea of non-binding ETA?
  • QuiteSmart
    QuiteSmart Posts: 67 image  Ally Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
    Anyone experiencing problems when clicking on "connect" (the connection doesn't start at all and one has toquit, eventually reboot and try several times)?
  • DavideASN
    DavideASN Posts: 2 image  Freshman Member
    sono passati 7 mesi dall'uscita di windows 11 e ancora non avete rilasciato una versione compatibile. Tutto ciò è inaccettabile per chi per scelta produce prodotti destinati al comparto Business. Ci aggiornate cortesemente! Grazie
  • Zyxel_Kevin
    Hi @DavideASN,
    Sorry for delay responded.
    We didn't suffer the issue on newly install client.Could you provide the error messages ?
    Or we can arrange the remote session directly.
    Kevin
