Switch GS1200-5 Series - V2.00 Patch 1 Firmware Release
Zyxel Switch GS1200-5 Series
Release Note
October, 2021
Firmware Version on all models
(Click Hyper link to download the firmware directly)
Zyxel GS1200-5 - V2.00(ABKM.1)
Zyxel GS1200-5HPv2 - V2.00(ABKN.1)
New Feature and Enhancements
No. | New Feature and Enhancements |
1. | Display per port status of LAG ports on system page. |
Bug fix
No. | Bug fix |
1. | [eITS#210301541] Unable to configure gateway address with 255 in last 8 bits, such as 192.168.0.255. |
2. | [eITS#210400598] When two GS1200 enabling loop prevention connect to the same switch-A, one GS1200 establishes a Link-aggregation with switch-A will cause another GS1200 inaccessible. |
3. | [eITS#210600977] Loop prevention not blocks ARP packet when a loop occurs causing switch crashed. |
4. | Firmware V2.00 and some of the prior firmware versions stores user password without being case sensitive. Firmware V2.00 patch 1 stores the first user password entered as case sensitive to enhance the user security of the Switch. |
Please refer to the Download Link for more details.
Adam
The "official" download link into support pagecontains the same firmware linked here?
Hi @mMontana,
Yes, you can check on URL of fimware link here and the link on support page, they are identical.Adam
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
