Can't figure out how to port forward USG20-VPN FW 4.31(ABAQ.0)
Zendata
Zendata Posts: 9 image  Freshman Member
edited April 2021 in Security
I have looked up numerous guides and youtube videos but most of the of the help is on an older version. I am using the latest version of the FW and still receive my connection is being rejected. My modemn is in bridge mode so I know that can't be the issue. I have attached screenshots so we can figure this out. The port I am trying to open is 32400. Any help? I've been going crazy over this.
Service Rule
Nat rule
Security Policy
«1
  • [Deleted User]
    [Deleted User] Posts: 118 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    edited July 2018
    Dear @Zendata
    as following
    Create service object:
    Create the nat rule!
    Note: NAT Loopback can be activated, so internal clients can contact server on the WAN IP-address. (Only if Original IP is not ANY.) therefore i filled in external ip
    And then The policy control --
    This should  work !
    otherwise make a copy of your log and post it here :-)
  • Zendata
    I dont understand the original IP vs mapped ip. Our screenshots are different. This didnt work for me it is still denying. How do I provide logging.
  • Zendata
    Also for the ending port, I cant specify it. When i specify 32400 for starting and ending and save. I reopen the service and the ending port is blank.
  • Zendata
    Your screenshots say internal vs external. I dont know how that relates to my screens.
  • Zendata
    I feel like we are lined up here idk what Im missing.
  • Zendata
    Key thing to note my modemn is in bridge mode on public dhcp lease.
  • Zendata
    The last thing I can possible think it could be is that zyxel is picking up my IP as a 192 address when my public is a 99.91 address (naturally).
  • [Deleted User]
    Internal external mapped or original  its all the same just other description..
    Everything is explained above..
    Use youre orignal ip : this is the public wan ip from your ISP
    Mapped ip is the nas ip internally
  • Zendata
    As you can see from the screenshots provided that is exactly what I have. I'm still being denied. How do I upload logs. I need this working before friday next week.
