USG40W DHCP over WiFi
I've lately installed a brand new USG40W. The device will only work via WiFi, non client ethernet connections at all. I've configured the Wifi SSID and options via the built in wizard.
The problem I have is that client are unalbe to renew their dhcp address, so every morning the device need to be restarted, which is not how it's supposed to be.
I've tried to force leased address renewals by shortening the lease time setting, I've also changed WiFi channel to avoind some interference by other SSID nearby, but I still haven't find a solution.
The device is outside the room where clients are located, but the signal is still pretty solid.
Any ideas about further setting I can optimize to solve this mistery?
Best regards
Nicola P.
Best regards
Nicola P.
Best Answers
Hi @Nicola_PWelcome to Zyxel Community.
We have addressed this issue, and fixed it in firmware.I send the firmware to you by private message.5 -
Thank you very much. I'll update the device today and post if any issue should arise.
Best regards
Nicola
Best regards
Nicola
- 588 USG FLEX H Series
- 477 News and Release
