Clients Cannot Surf the Net While Connectec via L2TP over IPSec on Flex200
NSIT
NSIT Posts: 20 image  Freshman Member
First Comment Sixth Anniversary
I just setup a new Flex200, remote users connected via L2TP over IPSec cannot surf the web when connected on VPN, any suggestions?
Thanks,
  • MJStar
    MJStar Posts: 37 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    You can navigate to the Web-GUI path of Monitor -> Log and see are there any blocked messages while you surf the web over L2TP connection? I think it's a clue. Maybe it is dropped by some security specific policies.
  • NSIT
  • NSIT
    I was able to resolve the issue by enabling split tunneling on the windows client side...Basically i believe this is a routing issue that can be resolved by enabling split tunneling on the ZyXel side as well but no one's available at support, apparently everythone's on the phone already and many are sick
  • NSIT
    Microsoft's Split Tunneling caused other issues such as loss of access to host ressources, connectivity to server & office computers, i had to take it off and add a route (thanks to Miguel from ZyXel)
