Site to site IPSec VPN: VLAN5 <-> LAN2 interface
Niels2021
Niels2021 Posts: 7 image  Freshman Member
Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula
I’m trying to set up a tunnel between a VLAN on 1 site and a regular LAN interface on the other site. The tunnel seems to work fine, but I cannot make any connection to the devices.
I have tried site to site and vti, both seem to connect, but cannot ping. Tunnel interface between 2 LAN interfaces is no problem, but I need VLAN <-> LAN2.
VPN_TEL_LOCAL Left: Subnet: 192.168.5.0
VPN_TEL_REMOTE Left: Subnet: 192.168.10.0
VPN_TEL_LOCAL Right: Subnet: 192.168.10.0
VPN_TEL_REMOTE Right: Subnet 192.168.5.0
Still no response on both sides. Any help?
    PeterUK Posts: 4,411 image  Guru Member
    You want site to site with at least one end nailed-up the status will show the tunnel is up
  • Niels2021
    They are both nailed up, status is also connected, so that's not the problem. I think it's the routing that I cannot get configured well
    If you have setup the Local and remote policy right with a zone for the site to site then you might need a routing rule.
    Incoming Interface
    member LAN/ge
    destination the remote subnet
    next hop
    type VPN Tunnel
    tunnel your zone for the site to site
    Then a firewall for LAN to zone site to site
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    edited January 2022
    What's about your Security Policy ? Have you allowed the traffic ?
    Also,Please check there is no  "Source Network Address Translation" applied.
