Google Authenticator not available on USG
TimBernhardson
in Security
Have USG40 running V4.65(AALA.1). According to the various docs and release notes I should be able to use Google Authenticator for both Admin & VPN Access, however the only options shown are SMS and email. What needs to be done to enable Google Authenticator?
Hi @TimBernhardson , enable two-factor authentication in user settings. I have it on firmware 4.70.
https://support.zyxel.eu/hc/en-us/articles/360018356680-Two-Factor-Authentication-with-Google-Authenticator-for-Admin-Access
https://support.zyxel.eu/hc/en-us/articles/4412733476114-Use-Google-Authenticator-for-2FA-VPN-connection
I already viewed those two docs, and the option for Google Authenticator is not there. I did some more digging - what version of USG do you have? Looks like it may be an issue where Google Auth is only supported on the "Cloud USG" E.G. USG-Flex Product, and not on the USG40.
I have Zywall 310.
On the demo page (https://zylab.zyxel.eu:4433/) of the UAG 60W gateway (it does not differ in functionality from yours) there is also a GoogleGoogle Authenticator setting. But there's firmware 4.70
Upgraded to 4.70 and the (partly) good news is that I now have the Google Authenticator option for Admin Access, Still only SMS or Email for VPN Access though. Guess I'll have to wait for a future upgrade. Thanks for the help.
Hi @TimBernhardson,
Google Authenticator for VPN access is available in ATP/FLEX series. You could use ATP/Flex series to get more feature comparing to USG40.
I have an USG Flex-500 and the "Auth. Method" page is like the one you posted.
But, even if I select "google authenticator", when I go in user's properties →two factor tab → enable two factor auth I see only mail and SMS.
What am I missing?
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
