Search MAC on XGS1210-12
New
New Posts: 1 image  Freshman Member
edited August 2022 in Switch
Can Multigig Switch XGS1210-12  show MAC Address Table to search  MAC locate on which interface ?   Thank you
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 313 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fifth Anniversary
    Hi @New,
    Welcome to Zyxel Community!
    XGS1210-12 doesn't support MAC address table feature, as GS/XGS1200 series was designed with basic web management features for Home/SOHO network environments.
    May I know what problem you've encountered that will need the mac-address-table?
    Jonas,
  • muetzekoeln
    muetzekoeln Posts: 46 image  Freshman Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Login via serial UART (4 pin connector on the right side). You can then show MAC address table by CLI command.
