GS1910-48 firmware. Where can I find it?
Best Answers
Hi @CAN,
Welcome to Zyxel Community!
Since GS1910-48 is already EOL, please click here to search GS1910-48 switch and download the latest firmware.
Don't hesitate to inquire us if there is any question.
Adam
Hi @CAN,
I just send the firmware V1.00(AAAZ.2) via private message to you, please check your mail inbox.
ThanksAdam
Hi @CAN,
Adam
Thank you for the quick response. Alas I'm unable to perform the upgrade. In order to follow the correct upgrade flow I need firmware version 1.00(AAAZ.2) before I can make an attempt to upgrade to the latest version.
Could you provide me the link to version 1.00(AAAZ.2)?0 -
Hi @CAN,
ThanksAdam
Thank you very much for the quick resolution.0
I have the same issue, my switch is still on Software version V1.00(AAAZ.0) and I need the firmwares to do the upgrade path, which looking at the comments means I need V1.00(AAAZ.2) before I can move to V2.00(AAAZ.0)C0, can anyone help with where to get the V1.00(AAAZ.2) firmware please?0
Hi @Babs,
Welcome to Zyxel community!
The attachment is the V1.00(AAAZ.2) firmware.
If you need other help, please feel free to create a post, our agent will help you.
Zyxel Melen0 -
my switch is still on Software version V1.00(AAAZ.2 can anyone help with where to get the V2.00(AAAZ.0)C0, firmware please?
Zyxel Melen0
Hi, I also have a GS1910-48 : is there a newer firmware than the one i have ? Where can i find it please ? Thanks
Software
Software Version
V2.00(AAAZ.0)C0
Software Date
2014-06-25T06:36:00+02:00
Code Revision
258cf9a62e22
Hi, Is there a newer version of the firmware for my GS1910-48 device ? Thanks
Software
Software Version
V2.00(AAAZ.0)C0
Software Date
Code Revision
258cf9a62e22
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
