NWA1123-AC-PRO different menu
For some unknown reasons objects created by the 'wizard' are not editable in the web interface. I changed that as follows:1. Download the configuration file to a PC2. Change the names manually by removing the prefix 'Wiz_'3. Upload the config file.After that the entries can be edited in the Web GUI.0
Hi @Wifi75 ,
You may create a new BSSID profile and disable the Wizard one.
If this doesn’t work, we suggest you apply system default configure and "skip" the wizard.
Then you can edit the profile name.
Thank you.
Silvia
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
