L2TP VPN for USG40 not working, impossibile to have server response, need mobile access.
Phoenix2875
Phoenix2875 Posts: 6 image  Freshman Member
edited April 2021 in Security
Hi to all, I need an help. I'm new to Zyxel, but not to firewalls and networking. A customer have installed in his company a branch office vpn with 2 USG 40W firewalls. The ipsec tunnel is correctly working. In the main site there's a single public ip in pppoe naked configuration. The previous sysadmin configured also an ssl client to site vpn and installed on the pc the windows Zyxel Client. All is working. Now customer wants to access with mobile (iOS) phone. I've configured vpn with and without the wizard for l2tp connection. Created an user object and associated in l2tp configuration. Wizard created correctly gateway in ipsec vpn settings and enabled l2tp configuration. All seems to be perfect, but when i try to connect i receive a "server didn't respond" error. Now..what can i check? i've tried to check port 443 (ssl) to public ip and it's correctly opened (for ssl vpn) but when i check 1701 for l2tp it gives me a "closed port". Provider told me that there's a transparent IP so, problem seems to be on USG. I' don't really understand what is blocking authentication...wizard is so simple..thank you.
  • ChrisGer
    ChrisGer Posts: 206 image  Ally Member
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    edited July 2018
    Hi  @Phoenix2875
    is one of the supportet Secure Extender Clients (SSL-VPN) compatible with your iOS ?
    Perhapse, ZYXEL can provide a pissibility for iOS to use the internal IPSEC Client like Android OS B)
    @Zyxel_Cooldia
    Has ZYXEL a guide to use the iOS internal IPSEC Client to get connected with pure IPSEC ?
    Regards
    Christian
  • Zyxel_Stanley
    edited July 2018
    Welcome to Zyxel community. :)
    The L2TP tunnel is working on ESP(protocol 50) but not SSL(port 443).
    And also ESP is allowed by default policy control rule.
    In your environment, USG is using for PPPoE connection.
    So you can make sure configuration first.   Configuration > VPN > IPSec VPN > VPN Gateway > WIZ_L2TP_VPN.
    My address should select as “wan_ppp” interface IP.
    And go to Configuration > VPN > IPSec VPN > VPN Connection > WIZ_L2TP_VPN.
    Make sure the local policy IP address is the same address as your PPPoE interface
    On your phone, you can make sure configuration again.
  • CHS
    CHS Posts: 181 image  Master Member
    Hi @ChristianG
    The link you provided is for Mac OS SecuExtender.
    As I know there is no SSL VPN client for mobile device. (e.g IOS or Android phone)
    The L2TP is Phoenix2875 required, and in my company there is no any problem to establishing L2TP VPN tunnel by my iPhone.
  • ChrisGer
    Hi @CHS
    it's correct, that there is no SSL-VPN for mobile devices (Android) ;)
    so i sent the link with the Applpe OS descriptions for a checkup.
    With Android, i'm useing IPSEC IKEv1 connection with the embedded VPN client in Android OS and decommissioned the L2TPoverIPSEC.
    @Phoenix2875
    "The ipsec tunnel is correctly working"
    So that's why i wrote... Ask ZYXEL if there is a way to connect directly with IPSEC and no L2TP configuration is required to get connected. ;)
    Regards
    Christian
  • Phoenix2875
    thank you all for now, i'll try some settings and post the solution that works. (if it works) :-)
  • Phoenix2875
    The problem was that Wizard select WAN instead of Wan_PPP. Changed to right one all working. thank you!.
