NWA1123-AC-PRO different menu
For some unknown reasons objects created by the 'wizard' are not editable in the web interface. I changed that as follows:1. Download the configuration file to a PC2. Change the names manually by removing the prefix 'Wiz_'3. Upload the config file.After that the entries can be edited in the Web GUI.0
Hi @Wifi75 ,
You may create a new BSSID profile and disable the Wizard one.
If this doesn’t work, we suggest you apply system default configure and "skip" the wizard.
Then you can edit the profile name.
Thank you.
Silvia
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 524 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
