June Incident: VPN 2FA & Disable HTTPS
MikeForshock
MikeForshock Posts: 60 image  Ally Member
We use 2FA on VPN for all users, this is reliant on the HTTPS service.
If we disable the HTTPS from WAN, we cannot authenticate.
Please create a review alternative methods to get us around this limit.
Perhaps make it so the VPN connection can only access the HTTPS (internal IP) until authenticated, versus blocking all connections.
  • MikeForshock
    Mostly fixed with latest 5.20 version.
    Allows for access to the 2FA server for authentication.  Would be a bit easier if it acted as a captive portal and automatically bring to authentication page versus manual entry.
