Problem Site to Site USG 210 and USG 20W
Hi
I have a problem for connect the USG.
I create VPN Site to Site, but not work.
I use this configuration....but the tunnel not Up.
https://support.zyxel.eu/hc/it/articles/360001378873-USG-ZyWall-Configurazione-da-sito-a-sito-VPN-IPSec
USG 210 has public ip 93.40.x.x
Local IP: 192.168.1.1
USG 20W has dynamic public ip (xxx.ddns.net)
Local IP: 192.168.0.1
For Remote policy use SUBNET 192.168.20.0/24 in USG210 and USG202W...
It's right?
I attach the error LOG
It's right?
No... configuration has to be specular.In each router's configuration "local policy" is local LAN, but "remote policy" network should be "local policy" of the other.1
Perfetto, ora il tunnel è UP, ma non riesco ad accedere alla rete remota.
Perfect, now the tunnel is UP, but I can't access the remote network.
E' meglio che ci parliamo in inglese, è la lingua ufficiale del forum. Altrimenti ci capiamo solo noi due e ti perdi parecchi commenti utili :-)So now tunnel is:USG 210: Local 192.168.1.0/24 Remote 192.168.0.0/24USG 20: Local 192.168.0.0/24 Remote 192.168.1.0/24Are you able to ping something? At least remote firewall?When you try to ping, do you see something in log?You could look at firewall rules on both device (directions ipsec-vpn-to... and ...to-ipsec-vpn) .0
I try ping remote network, but not risponde.
I attach the firewall rules... i create rules Ipsec to Lan1 and lan1 to ipsec.. but not work.
Thanks for support
Neither remote firewall is responding?You could try, in "vpn monitor", a connectivity check pointing LAN IP of remote firewall.You could try to activate "log" in relevant firewall rules, to see if it detects something.0
HI @Manuel13
Please check if "ZONE" includes your VPN Tunnel or IPSEC will not work for Traffic.
If you need a remote check to fix this issue, please be in touch with Europe Support Team:
https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354
Kind Regards,
Tobias0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
