Is the VPN2S EOL because its time is wrong
So don't know if the VPN2S was a mistake zyxel would like to forget or a one off cheap router with firewall as its QoS hits it to 50Mb limit as I found out.
just put firmware V1.20(ABLN.2)_00210624C1 and its current time/date is wrong
So my USG/VPN use my PC win 11 to Get Time 192.168.255.250 but the VPN2S don't get the time/date by that IP but using the pre-set time servers works.
Hi Peter,
can you help to log a ticket for deeper investigation into it?
https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354
Thanks.
Tobias0 -
Ok done0
Hi Peter,
well, I see the case and add myself into it. Our Agent will collect needed things and I´ll make sure that you see progress next week.
Regards,
Tobias
So its closed with Will check on this aspect of the LAN internally with my development team for getting time by LAN side but my guess is their will not be a update to fix this any time soon or at all and just get time from WAN side.
Its interesting who coded the VPN2S how it sends out a time request LAN side only to not accept the reply.0
- 588 USG FLEX H Series
- 477 News and Release
