USG310 - Block traffic to Management but not to Internet
[Deleted User]
in Security
I'm really struggling on this one.
I have an USG310 and NWA5123 as AP. Maybe the problem is easier than I think to solve but I just can't figure it out.
The USG is accessible under the default IP 192.168.1.1 and for the AP I set 192.168.10.1. Now I wan't to block the connection to 192.168.1.1 for the AP.
I think there is a specific firewall rule which I need to set but I didn't find them yet.
One thing I tried is block AP traffic to ZyWall but if I do this, the AP shows as offline in AP Management.
For managing the Switch I'm using LAN on a other port than the AP.
Hi @Lukas0102
True, you need to block AP to ZyWALL but if ZyWALL manages this AP you need 2 rules:
a) Allow AP to ZyWALL with "Services: CAPWAP"
b) Block AP to ZyWALL with any services
So you can make sure your Management WIFI is working, but PING is blocked
Also, you can do:
a) Block "AP to ZyWALL" with Service "PING"
b) Allow "AP to ZyWALL" with Service "Any"
To may not run into more Port block issues.
Kind Regards,
Tobias0
Hi @Lukas0102
Also, you can do:
Kind Regards,
Tobias0 -
Thanks for the answer. I forgot to set a custom DNS instead of the ZyWALL for the AP zone...Zyxel_Tobias said:Hi @Lukas0102
Also, you can do:
Kind Regards,
Tobias
- 588 USG FLEX H Series
- 477 News and Release
