GS1900-8 Firmware V2.70(AAHH.1) Unknown
Julien_ALM
Julien_ALM Posts: 10 image  Freshman Member
edited August 2022 in Switch
I uploaded the new firmware v2.70 (AAHH.1) for the GS1900-8 switch but it is not recognized. (see screenshot)
Unknown Firmware ?
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Julien_ALM,
    I can reproduce the same symptom in my local test.
    It seems like a display problem because it backs to normal after I use the V2.70 firmware to reboot.
    Therefore, please feel free to reboot with the new firmware.
    Thanks for your feedback, we will track this display problem and solve it in the next new firmware.
    Jason
  • Zyxel_Jason
    Hi @Julien_ALM,
    Jason
  • Julien_ALM
    Hi @Zyxel_Jason,
    I Have restarted the device and everythig seems to be OK !
    Thank You !
