NWA210AX, NWA100AX, NWA50AX Antenna Propagation
jpblanch75
Can you supply this data for me?
Would be nice if this was available to download from the support page of each AP.
Thanks!
Thanks!
Best Answers
Thank you!0
Thank you!0
So looking at the antenna spec files for the 210AX .. the preferred place would be the sealing instead a not exterior wall. Is this correct?0
I would say based on the propagation you could place them on walls no problem. I am using them that way. You just need to know that the antenna has more gain off the front side than it does off the backside.MonsterD said:So looking at the antenna spec files for the 210AX .. the preferred place would be the sealing instead a not exterior wall. Is this correct?0
- 588 USG FLEX H Series
- 477 News and Release
