VPN2S, no access on "inside" nor Internet
Hi @USJKPAS
You can navigate Web-GUI Configuration > NAT > Port Forwarding > Add > Add a port forwarding rule and then you can access your VPN2S LAN area host. Such as the following example you can access internal web server.
Hi, is there a way to enable the above via CLI via a Ssh connection?0
Hi @Josta
It’s not recommended to configure the settings by using CLI since it’s mainly used for troubleshooting instead configuration. Feature deployment via CLI may not as completely/straightforward as GUI.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
