GS1910-48HP firmware
Hi, i do have an GS1910-48HP try to upgrade from
V1.00(AABA.0)
2012-04-24T05:02:09+02:00
to the latest version but looks like it isn't working direct to 2.70(AAHO.1)C0 via WebGUI.
i found a couple of threads directing me to ftp.zyxel.com or else ftp2.zyxel.com but i can't find any old firmware around there.
can you provide me a link or send me the versions in need to upgrade to before i can use 2.70?
any help is much appreciated!
Hi @felt_b2
Welcome to Zyxel Communtiy!
The firmware 2.70(AAHO.1)C0 is for GS1900 series, not for GS1910.
The attached are the firmwares for GS1910-48HP to upgrade.
Kindly remind, GS1910-48HP need tofollow the upgrading flow below:
Hope it helps.Zyxel Melen0
Hi @felt_b2
Hope it helps.Zyxel Melen0 -
Thank you, Melen! all updated and working fine
- 3K Nebula
- 231 Nebula Ideas
- 6.6K Security
- 672 USG FLEX H Series
- 360 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 500 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
