GS1350-6HP: can I use the SFP port as downlink?
For this switch, and most other similar ones, the SFP port is documented as an uplink port, meant for backbone usage. Is this port usable just like any normal RJ45 port, are they all equivalent from the network topology point of view? I.e. one of the switch's RJ45 ports would be the uplink connected to my router, and the SFP port would be connected to something else downstream, maybe my NAS or another switch of the same type.
Hi @joco74,
Welcome to Zyxel Community!
Regarding your question, of course you could make SFP port as downlink to your NAS or other switch for faster network transmission. There is no any limitation of this application.
Most of the documents usually put SFP/SFP+ port as uplink port only.
Hope it helps.Adam
Hi @joco74,
Hope it helps.Adam
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
