USE SPECIFIC WAN IP FOR NAVIGATION
Good morning at all,
my client has an ATP200 with multiple Public IPs on the same WAN port.
We want to configure that all servers use the first public IP and the rest of the LAN use the other another IP.
ATP200 config:
Public IP 1 --> 80.xx.xxx.x1
Public IP 2 --> 80.xx.xxx.x2
LAN --> 192.168.0.x
Servers --> 192.168.0.220-230
PCs --> 192.168.0.101-199
We want to use WAN IP 1 for servers and WAN IP 2 for clients.
How can I do this?
Thanks a lot.
Leandro
ATP200 config:
LAN --> 192.168.0.x
How can I do this?
Thanks a lot.
Leandro
Hi @Leandro85,
Greeting,You could use Policy Route to implement the requirement.
Please kindly find the following:
1) WANIP_1 for 80.xx.xxx.x1 , WANIP_2 for 80.xx.xxx.x2
2) Source: PCs Destination:any -> SNAT:WANIP_1
Source: Servers Destination:any -> SNAT:WANIP_2
Kevin
Writing correct routing rules. Assuming that your firewall is already correctly configured with multiple public IPs (same interface or not, that does not quite change the things).Leandro85 said:How can I do this?
Moreover: AFAIK using two different public IP addresses wont' change the available bandwidth or should not chage BandWidthManagement in any way, if the firewall is not instructed appropriately.0 -
Hi @Leandro85,
Kevin
Thanks a LOT!!!
This is what I was trying to do! Thank you very much for the reply, I have done the configuration and everything finally works as we wanted. Thanks again! Have a nice day and have a good weekendZyxel_Kevin said:Hi @Leandro85,Greeting,You could use Policy Route to implement the requirement.
Kevin
A WAN IP address is your public or global IP address. Your computer uses this to access the internet via the wide area network
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
