USG20-VPN low internet LAN speed comparing to WAN
Hi.
I'm experiencing a strange issue with that FW.
The internet connection speed took from Fiber line router is about 850 Mbit/sec (1Gbit contract).
Looking at the FW control panel, the LAN1 connection is regularly negotiated at 1000M (1Gbit) but the internet speed is capped at 400/420 Mbit.
No way to get the 850 that router can provide.
Is there any kind of hidden speed control i can't see in FW control panel?
Regards
Regards
Hi @toxstoxs,
In datasheet, the USG20-VPN performance is around 350~400 Mbps.
We would suggest swap to ATP or FLEX series for better performance.
Specifications:
USG20-VPN
https://www.zyxel.com/products_services/Business-Firewall-USG20-VPN-USG20W-VPN/specifications
ATP series
https://www.zyxel.com/products_services/ATP-Firewall-ZyWALL-ATP100/license-and-spec
I have a Zywall USG20, my navigation speed through the internet is limited to 100Mbps even if the device is rated to 1Gbps… I know that this device has a limitation of 75Mbps over VPN, but the speed I'm referring to is the speed test of the LAN network.
Best
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
