wirelles extender
Hi @saibko
Could you share with us about the project detail?
1. topology
2. will the customer use controller?
3. what kind of the service will be used?
4. it is 2.4G or 5G?
5. any specific usage?
Please let us know the information so that we will know how to help you to deploy the environment.
Thanks for your help.
Joslyn1 -
Hi livealive we like to use signal extension like WSD topology.
your advice0 -
Hi @saibko
WAC6103D-I supports WDS ( Wireless Distribution System ) for signal extension.Here are some suggestions:1.The max number of repeater APs can connect to one root AP is 5 (1 root AP + 5 repeater APs).2.The suggested hops number of APs build the WDS the max limitation is 2 for throughput concern.For example, there are three WAC6103D-I that build the WDS.
The topology of them with 1 hops as follows:<Ethernet>---Root AP ) ) ) WDS ( ( ( Repeater AP
The topology of them with 2 hops as follows:<Ethernet>---Root AP ) ) ) WDS ( ( ( Repeater AP ) ) ) WDS ( ( ( Repeater AP
Hi @saibko,
We suggest to use 2.4G to establish WDS and 5G to service the stations. Please separate the channels between the APs for service, or you can use DCS to choose the best channel to use; however, remember to disable the DCS for 2.4G since it is used to establish WDS. If enabling DCS, it will cause the WDS down since the channel changes.
The distance between the root AP and repeater is not longer than 10 meters.
Here is the handbook to teach you how to configure the WDS. Please refer to the chapter 2.3.
ftp://ftp2.zyxel.com/NXC2500/handbook/NXC2500_NXCControllerSeriesHandbookVersion2.pdf
Thanks.
Joslyn0
- 603 USG FLEX H Series
- 481 News and Release
