Automatic Backup of Switch Configurations.
Kinshuk_Tech
Hi there,
Recently we are undergoing implementation of several ZyXEL switches in an enterprise customer. Switches include XGS4600, XS3800, MGS3750, XS1930, XGS2210, XGS2210, GS1920, GS1350 in good quantities. I know, there is an option to take backup individually, by going into each switch UI. But it takes only config log. Not running configuration.
But, now customer wants to setup an automatic backup for running config of all switches, at specific frequency ie. month, date, time etc.
How can this be achieved? I have gone through almost all places, but couldn't find anything around this.
Any help, will be highly appreciated.
Hi @Kinshuk_Tech,
Welcome to Zyxel Community!I know, there is an option to take backup individually, by going into each switch UI. But it takes only config log. Not running configuration.First, may we know which switch model cannot back up running config but config log only? Zyxel switch should be able to back up either running configuration or startup configuration(Config 1 & Config 2) individually via switch GUI.But, now customer wants to setup an automatic backup for running config of all switches, at specific frequency ie. month, date, time etc.Sorry that Zyxel switch does not offer feature of auto backup config. If you would like to achieve it, you may use other 3rd party tool on customer's network.
Adam
So here the questions, does all these models
(1)support to use SNMP to backup configuration to external TFTP server ?
(2)support use CLI to backup to external TFTP server ?
(3)support use CLI "show running-config" ?
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015782&lang=EN
https://community.zyxel.com/en/discussion/3496/gs1900-and-gs1920-config-backup-to-tftp-with-snmp-commands
You are right. @Zyxel_Adam. I didn't see it thoroughly.Zyxel_Adam said:Hi @Kinshuk_Tech,
Yes, almost all ZyXEL devices have the option to select running configuration and startup configuration as well, albeit, it needs to be done, one-by-one and cannot be taken simultaneously.0 -
Hi @lan31,Ian31 said:So here the questions, does all these models
Please check the following table regarding your question:
Adam
Here a sample Python script that using telnet to device and use show run command to dump configuration to a file.
- 588 USG FLEX H Series
- 477 News and Release
