Match default rule, DROP
RBattaglia
in Security
Hello All,
I have a VPN100 that has been set up correctly with a service for the port I need to use to forward our accounting traffic to the server. I have also created the Policy Control to allow it to go to the correct IP address and have created a NAT rule to allow it in. But for some reason the default rule is constantly blocking it with
Security Policy Control | Match default rule, DROP [count=3]. I don't know what I am doing wrong or missing. I have now been on hold with Zyxel Support for almost an hour with anyone picking up - very frustrating. Any suggestions would really help. |
I was finally able to get through to a tech and found out that the settings for NAT rules are a bit different on the new VPN units versus the old USG ones. I had the WAN in the wrong location in the rule. All is working fine now.0
Hi @RBattaglia,
You may check corresponding security policy to see if it matches the criteria From and To.
Most fail case on mismatch security policy criteria zone setting From and To.
- 603 USG FLEX H Series
- 481 News and Release
