MAC Filter on USG40W
Dear All,
on CONFIGURATION MENU (Expert mode) path "OBJECTS, APP, SSID, MAC FILTER LIST" I can edit a MAC address list to deny access at specific MAC pc address, but from SSID LIST i can't enable the MAC FILTERING function just created (the massage is ONLY EASY MODE).
In the Easy mode there is no way to edit the SSID to enable the MAC FILTERING.
The question is: may USG40W manage a MAC ADDRESS LIST ? Is possible create and manage a MAC Address "Black List"?
Thanks for the reply
I delete all of EASY MODE AP setup and just use Expert mode to setup the AP
Like PeterUK saied. Just use Expert mode to setup AP.
Thanks a lot
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
