Block all GEO IPs execpt one
PeterHer
PeterHer Posts: 18  Freshman Member
Hi All,
Is it possible to block all GEO IPs except one?
I know it is possible to deny a GEO IP, but I have to add all of them, which is very cumbersome.
I have an USG40 and USG210.
I hope someone can help me.
Thanks in advance.
Peter
  • p4_greg
    p4_greg Posts: 29  Freshman Member
    Network Detective-New Adventure Badge First Comment Friend Collector Third Anniversary
    If you want to allow only USA IPs(for example), you can do it with 2 firewall rules.
    The first rule allows all USA GEO-IPs, the second rule blocks all other IPs.
    Rule #1:
    To: LAN
    Source: USA_GEO_IPs
    Action: Allow
    Rule #2:
    To: LAN
    Source: any
    Action: Deny
  • p4_greg
    Rule #1:
    To: LAN
    Source: USA_GEO_IPs
    Action: Allow
    Rule #2:
    To: LAN
    Source: any
    Action: Deny
  • mMontana
    mMontana Posts: 1,432  Guru Member
    @PeterHer would you please articulate/expand a bit more your question?
  • PeterHer
    edited February 2022
    Well I only want to give Dutch IP addressees access to my server, which is behind an USG210.
    I want to block all other IP addresses. But with the above suggestion and this video (https://support.zyxel.eu/hc/nl/articles/360001378533-Hoe-de-Geo-IP-functie-te-gebruiken), it seems that this problem has been solved.
    Thank you.
  • mMontana
    Not all the community is familiar with spoken Dutch, so I will try to simplify how this goal could be achieved.
    Rule #1:
    To: LAN
    Source: Allowed IP Address
    Action: Allow
    GeoIP should not be necessary if you're allowing only one (or some) ip addresses, unless there are some more angles and rules about it.
