ZYWALL USG20W keeps rebooting
I've been using my Zywall USG20W for many years without any problem.
In the last few weeks it keeps rebooting, randomly, every 10/20 minutes, after it goes to 100% CPU usage.
I have updated the firmware to 3.30(BDR.9) / 1.15 / 2016-11-22 10:05:22, but still the same.
Adding some info. The log shows these recurrent alerts by App Watch Dog:
- ctipd.bin is dead at (date/time)
- App watch dog recover ctipd.bin dead at the 3 time
- App watch dog stop to recover ctipd.bin. Daemon state: dead
- diagnostic-info is collecting now. Wait it to complete [*there are a few identical entries of this alert]
I noticed that, after these alerts, CPU usage keeps growing up to almost 100%, then the device reboots.
Any ideas?
Any ideas?
Try another switching power supply.
If your current powerbrick is unable to deliver up to 1.5A - 12V the power consumption could be higher than available and make your device reboot. Upt to 3A power brick won't harm the firewall, but check the polarity of the connector before try.Look for the latest WK firmware.AFAIK this is a semi-official release, with some bug fixed and a certified TLS 1.2 support. Date of release is 1/12/2016. It's still an old and insecure/unpatched firmware for more recent vulnerabilities. This won't necessary mean that your device will stop rebooting, if it's fault/broken in any part, a newer firmware won't ease the issues.Consider to reset the device and to create from start the configuration. USG20 went from 2.x to 3.x firmwares so maybe the configuration could contain something not nice for the most current firmware version. Should not happen, but...0
The same question as these two posts. Find the suggestion and the latest release.0
Thank you for your answer. I already checked the posts. I have the latest Firmware installed 3.30(BDR.9). Still the same problem.0
If your current powerbrick is unable to deliver up to 1.5A - 12V the power consumption could be higher than available and make your device reboot. Upt to 3A power brick won't harm the firewall, but check the polarity of the connector before try.Look for the latest WK firmware.AFAIK this is a semi-official release, with some bug fixed and a certified TLS 1.2 support. Date of release is 1/12/2016. It's still an old and insecure/unpatched firmware for more recent vulnerabilities. This won't necessary mean that your device will stop rebooting, if it's fault/broken in any part, a newer firmware won't ease the issues.Consider to reset the device and to create from start the configuration. USG20 went from 2.x to 3.x firmwares so maybe the configuration could contain something not nice for the most current firmware version. Should not happen, but...0 -
Thank you very much for your answer. After reset and reconfigure from start inclusive Firmwareupdate to the firmware to 3.30(BDR.9), the USG20W does not reboot anymore.
Thank you.0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
