Block all GEO IPs execpt one
If you want to allow only USA IPs(for example), you can do it with 2 firewall rules.The first rule allows all USA GEO-IPs, the second rule blocks all other IPs.Rule #1:From: WANTo: LANSource: USA_GEO_IPsAction: AllowRule #2:From: WANTo: LANSource: anyAction: Deny
Well I only want to give Dutch IP addressees access to my server, which is behind an USG210.I want to block all other IP addresses. But with the above suggestion and this video (https://support.zyxel.eu/hc/nl/articles/360001378533-Hoe-de-Geo-IP-functie-te-gebruiken), it seems that this problem has been solved.Thank you.
Not all the community is familiar with spoken Dutch, so I will try to simplify how this goal could be achieved.Rule #1:
To: LAN
Source: Allowed IP Address
Action: AllowGeoIP should not be necessary if you're allowing only one (or some) ip addresses, unless there are some more angles and rules about it.0
- 441 Beta Program
- 293 Service & License
