NWA50AX V6.25(ABTF.5): Where is 80 MHz @ ch132–144 and UNII-3:ch149–161?
why is the 80 MHz channel block from ch132–144 not available?
This is just intangible to cut off UNII-2-Ex at ch128. What's wrong with this device?
Well, and of course, where's the 80 MHz band of UNII-3:ch149–161?
Btw, we're in the EU (Germany) here and I never had any radar/DFS issues (or messages about detection).
Best regards...
Best regards...
Hello customer,
Based on the Spec, NWA50AX supports [5.15 to 5.35] GHz and [5.470 to 5.725] GHz in the EU region, while channel 144 is ranging from 5.71 GHz –5.73 GHz, so it's not supported by our AP, So does the UNII-3 channels. Hence in the Web GUI you can't select those channels.
(https://www.zyxel.com/products_services/802-11ax--WiFi-6--Dual-Radio-PoE-Access-Point-NWA50AX/specifications)
Best Regards,
Richard0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
