Site to site bug or limitation
Zywall 110 V4.70(AAAA.0)ITS-WK46-r102519 |
VPN300 V5.20(ABFC.0) |
So was playing around as packet loss bug is being looked into if I could route internet traffic down a site to site tunnel this is my setup with OPT on the Zywall 110 for the internet:
added some routing rules...
...and 192.168.255.50 send ping 1.1.1.1 to gateway 192.168.255.49 on VPN300 send down the tunnel to Zywall 110 out OPT reply comes back...and thats it will not NAT and send down tunnel bit disappointing if its a limitation...or is it a bug?
"Interface type" have different meanings.
Have you change the "OPT" interface type to "external"?
Hi @PeterUK,Greeting Forum.Could you kindly provide all configuraion file via Private Message (include the device "Doing NAT")?On the other hands,For your inquiry.Route-based VPN would more flexible .Could you try route-based VPN?Kevin0
Thanks both this is solved thanks to zyman2008
On the Zywall 110 I changed the Local policy to a object “all” 0.0.0.0 – 255.255.255.255 this was not enough to solve so on the VPN300 I changed remote policy to “all” and it works.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
