Site to site bug or limitation
PeterUK
PeterUK Posts: 4,139 image  Guru Member
edited February 2022 in Security
Zywall 110 V4.70(AAAA.0)ITS-WK46-r102519
VPN300  V5.20(ABFC.0)
So was playing around as packet loss bug is being looked into if I could route internet traffic down a site to site tunnel this is my setup with OPT on the Zywall 110 for the internet:
added some routing rules...
...and 192.168.255.50 send ping 1.1.1.1 to gateway 192.168.255.49 on VPN300 send down the tunnel to Zywall 110 out OPT reply comes back...and thats it will not NAT and send down tunnel bit disappointing if its a limitation...or is it a bug?
  • zyman2008
    zyman2008 Posts: 236 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    edited March 2022 Answer ✓
    Hi @PeterUK,
    From the tunnel configuration on ZyWALL 110.
    Only traffic from 192.168.138.0/28 to 192.168.255.48/28 will go into the tunnel.
    Do you add a return route on ZyWALL 110 for any to 192.168.255.48/28 into the tunnel ?
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    "Interface type" have different meanings.
    Have you change the "OPT" interface type to "external"?
    Yes it set to external the reply just does not NAT back down the site to site tunnel
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958 image  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Greeting Forum.
    Could you kindly provide all configuraion file via Private Message (include the device "Doing NAT")?
    On the other hands,For your inquiry.Route-based VPN would more flexible .Could you try route-based VPN?
    Kevin
  • zyman2008
    Hi @PeterUK,
    Thanks both this is solved thanks to zyman2008
    On the Zywall 110 I changed the Local policy to a object “all” 0.0.0.0 – 255.255.255.255 this was not enough to solve so on the VPN300 I changed remote policy to “all” and it works.
