Turn Old Zyxel USG20 To Manageable or not Network Switch ?
Loganxwolverine
Dear all,
I am searching for a good alternative, and then,
How to turn Old Zyxel USG20 (for instance) into a manageable Switch ? Or non Manageable.
The idea is to recycle and give another life to these old product.
And then, yes of course, How to Use add Wan Port ?
So many thanks for your help in advance.
Just disable the DHCP service on the LAN, or you can even configure it as a router role if you want.0
- 588 USG FLEX H Series
- 477 News and Release
