voice vlan gs2200
KleinStreisend
KleinStreisend Posts: 6 image  Freshman Member
Friend Collector
edited August 2022 in Switch
Can you please tell me if this model supports Voice vlan? I did not find the option to configure in the web interface. It is necessary that the IP phone be in its vlan.
Zyxel gs2200
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,732 image  Zyxel Employee
    edited March 2022 Answer ✓
    Hi @KleinStreisend,
    GS2200 does not have Voice VLAN feature, if you need this feature, I suggest to use GS2220 series switch or GS1920 series switch to reach your requirement.
    Or you can use Subnet Based VLAN which is a similar feature with Voice VLAN that it can add VLAN tag to untagged packet from different subnet.
    Hope it helps.
    Zyxel Melen
