NWA50AX adding printer
Mjd0604
Mjd0604 Posts: 3 image  Freshman Member
edited May 2024 in Wireless
Installed my NWA50AX into my outhouse office. Perfect connect to all devices apart from my printer. Is there anyway to active WPS with it? I don’t have a cable for the printer to assist with setup.
  • jpblanch75
    jpblanch75 Posts: 187
    First Comment Friend Collector Fourth Anniversary Community MVP
    image  Master Member
    It's doesn't have a display on it to connect wifi?
    What's the make and model?
  • Mjd0604
    Expression Home XP-235 All-in-One Inkjet Printer Compatible XL Ink
    Crappy cheap thing!
  • jpblanch75
    image  Master Member
    Crappy cheap thing!
    I can't find any info for WPS support at all on these APs.  I will say that your printer may not work with WPA2 Wi-Fi security so you may need to use WPA for your 2.4ghz.  Also ensure you have "Allow 802.11ax/ac/n stations only" setting disabled.
    Are you using Nebula?
    Can you setup your AP to use the exact same wifi SSID and Password you had with your old wifi router or AP?
    Jason
  • Zyxel_Richard
    Zyxel_Richard Posts: 260
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    image  Zyxel Employee
    Hi @Mjd0604
    Checked the printer's Wi-Fi capability, it only supports WPA-AES/TKIP security settings. And by default our APs use WPA2 to reach stronger security, which will make the printer unable to connect to Wi-Fi.
    Besides, our AP doesn't support WPS. So you need to manually enter the password for Wi-Fi access.
    In order to let the printer access the Wi-Fi, you can use "WPA2-Mix" at the security setting page (standalone AP).
    If the AP is managed by Nebula, you may first disable the "simple mode" in the [SSID Setting page], and go the  [SSID advanced settings] page, configure the Security with "WPA-Personal with WPA1"
    Best Regards,
    Richard
  • Mjd0604
    Thank you Richard.
    im going to treat myself to a new printer with on screen WPA2 WiFi settings, that way it will make my life easier.
