NWA50AX adding printer
It's doesn't have a display on it to connect wifi?
What's the make and model?1 -
jpblanch75 said:It's doesn't have a display on it to connect wifi?
What's the make and model?Expression Home XP-235 All-in-One Inkjet Printer Compatible XL InkCrappy cheap thing!0 -
I can't find any info for WPS support at all on these APs. I will say that your printer may not work with WPA2 Wi-Fi security so you may need to use WPA for your 2.4ghz. Also ensure you have "Allow 802.11ax/ac/n stations only" setting disabled.Mjd0604 said:jpblanch75 said:It's doesn't have a display on it to connect wifi?
Are you using Nebula?
Can you setup your AP to use the exact same wifi SSID and Password you had with your old wifi router or AP?
Jason0 -
Hi @Mjd0604
Checked the printer's Wi-Fi capability, it only supports WPA-AES/TKIP security settings. And by default our APs use WPA2 to reach stronger security, which will make the printer unable to connect to Wi-Fi.
Besides, our AP doesn't support WPS. So you need to manually enter the password for Wi-Fi access.
In order to let the printer access the Wi-Fi, you can use "WPA2-Mix" at the security setting page (standalone AP).
If the AP is managed by Nebula, you may first disable the "simple mode" in the [SSID Setting page], and go the [SSID advanced settings] page, configure the Security with "WPA-Personal with WPA1"
Best Regards,
Richard
Thank you Richard.
im going to treat myself to a new printer with on screen WPA2 WiFi settings, that way it will make my life easier.1
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
