Can't remove certificate object
Hello community,
I would like to remove an expired certificate on my
USG FLEX 50W (USG20W-VPN) but when doing so over GUI I get the following message:
"Wrong CLI command, device timeout or device logout."
Trying to remove it using CLI I get this:
"Router(config)# no ca category local <certificate name>
% (after 'local'): Parse error
retval = -1
ERROR: Parse error/command not found!"
What do I need to do to finally get rid of it?
Thank you.
Regards
Firmware version: 5.21(ABAR.0)
Thank you.
Regards
Hi @alehzn
You can login to device WebGUI to backup(download) the certificates that you needed.
And then use CLI command to flush all of certificates on your device.
System will regenerate system default certificates and flush others.
Router# debug _ca regenerate
Hi @alehzn,Thanks for your feedback.We will check on this problem and get back to you when there is any progress.Thank you.James0
Hi @alehzn,
Before input the command "no ca category local [certificate_name]", we should input "configure terminal" first to entering Configure mode.
Here are screenshots for your reference.
1. "show ca category local" >> Check what certificates we have, here I take "0311james" for example.
2. Input "configure terminal" for entering configure mode, and then input "no ca category local 0311james" to remove the certificate.
3. Then we can see there is no more "0311james"
Please try this solution, I'm looking forward to the result, thank you.
James.
Hello James,
thank you for the instruction which I have already followed before.
Please see screenshot attached. You will notice that it (still) does not work.
Best0 -
Hi @alehzn
Hello @Zyxel_Stanley
The command did the trick. Certificate is finally gone. Thank you for your great support!0 -
Hi @BrowB
Does your certificate was expired on your device and it is unable to remove from WebGUI or CLI?
If not, can you export the certificate and share it to us?0
- 588 USG FLEX H Series
- 477 News and Release
