L2TP VPN Split tunnel configuration
Hi there!
I am curious about L2TP VPN and possibility to connect to it via 'Split tunnel'?
Why am I asking? I am only able to run L2TP VPN connection from Mac and Linux instances with 'Send all traffic over VPN connection' option checked.
But I don't want to use full tunnel for this kind of VPN.
Is is possible? Is there some certain settings what I have to change? Can somebody provide some manual?
Thanks to all!
Not just un-check the 'Send all traffic over VPN connection' .
You need manual add route to the tunnel interface,
1. Check the interface name of vpn by command 'ifconfig'
2. Add route,
route add -net <destination subnet> -netmask <subnet mask> -interface pppx
3. Verify the routing table
netstat -r
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
