Upgrading from a USG 50 to a USG 110 using USG Convertor
dcgtechnologies
Hello....I am trying to upgrade my firewall from a USG 50 to a USG 110 and I was using the USG Configuration Convertor. It says this is supported I converted the file correctly, but I get an error below:
ermo: -39010
ermo: Invalid or other Model's configuration file
and I know the firmware on the USG 110 is V4.32(AAAA.0) and the firmware on the USG 50 is V3.30(BDS.7). Any ideas would be helpful? Is there something else I am missing? I would like to upgrade my firewall, but do not want to recreate all my settings. That could take forever. Thank you.
ermo: -39010
Did you use configuration convert before uploading configuration to USG110?
https://convert.cloud.zyxel.com/
It looks you uploaded USG50 configuration to USG110 directly..
Because this error is coming from configuration exist USG50 model info in the title.
Yes I converted the file first and then I get the same error when trying to upload the file to the USG 110. Do I nedd to do something else? I followed the online instructions. Thank you.0
Well an update I called into support and found out the tool does not support the Zywall 110, but only the USG110. There is a difference between the two. I ended up manually copying the settings from old USG 50. So all is good now. Thank you for all your help.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
