Content Filter Blocks Communication with Dataserver from Application (NinjaTrader.exe)
Hello @MarcelG,When Content Filter blocks NinjaTrader.exe, what did the logs show?The logs should show the information about the blocked URL if it's blocked by Content FilterYou may check the logs first to know which URL is blocked by Content Filter when using NinjaTrader.exe, then add it to Trusted Web Sites.Thank you.
James0 -
I don't know where I find the log, when I open the Page of Monitor - UTM-Statistics - Content Filter, the counter of blocked is = 0 (I started the application some minutes before)
Hello ?0
Hi @MarcelG,
1. Navigate to Configure > Security Service > Content Filter, and open the web content filter profile. Tick "Enable Content Filter Category Service" and "log all web pages"
2. Navigate to Configure > Log & Report > Log Settings, edit System the Log profile and scroll down to Active Log and Alert, please make sure Security Service is ticked as "Normall" on Systm log section.
After the settings above, you may check the logs at Monitor > View Log. Thank you.
James.
I've no Option "Security Service", "Content Filter" is only under UTM Profile
I've no Option "Security Service", "Content Filter" is only under UTM Profile (see preview post)
Hello @MarcelG,
For USG110, the Content Filter is under the UTM Profile instead of Security Service. You may still follow the steps to tick "Enable Content Filter Category Service" and "log all web pages" at Content Filter profile and edit the system log. Thank you.
James0 -
MarcelG, Ninjatrader software will connect to their database server.
You can to add *.ninjatrader.com in Trusted Web Sites what Zyxel_James mentioned.
Also monitor if there is any block log in USG system log entries.Zyxel_James said:Hello @MarcelG,When Content Filter blocks NinjaTrader.exe, what did the logs show?The logs should show the information about the blocked URL if it's blocked by Content FilterYou may check the logs first to know which URL is blocked by Content Filter when using NinjaTrader.exe, then add it to Trusted Web Sites.Thank you.
James
I Did all what you recommend mewww.ninjatrader.com in trusted web sites it didn't work.When I show the Log with filter "Content Filter", i didn't show me anaythingFinaly with the option "all logs" I found:Warning web sites acmeanalytics.net : unrated, Rule_id=2, SSI=N (HTTPS Domain Filter)I Put "www.acmeanalytics.net" in trusted sites, it didn't workwith "acmeanalytics.net" it worksThank you for your help
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 667 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 499 News and Release
- 96 Security Advisories
- 5K FAQ
- 89 About Community
- 111 Security Highlight
