NebulaFlex Switch GS1920v2 Series - V4.70 Patch 6 Firmware Release
Zyxel_Jonas
Zyxel Switch GS1920v2 Series
Release Note
February, 2022
Firmware Version on all models
Zyxel GS1920-48HPv2 - V4.70(ABMK.6)
Zyxel GS1920-48v2 - V4.70(ABMJ.6)
Zyxel GS1920-24HPv2 - V4.70(ABMI.6)
Zyxel GS1920-24v2 - V4.70(ABMH.6)
Zyxel GS1920-8HPv2 - V4.70(ABKZ.6)
New Feature and Enhancements
Bug fix
CLD=Cloud mode, STD=Standalone mode
No. |
Bug fix |
CLD |
STD |
1. |
[eITS#210501222] Web GUI login page may encounter display error or problem to display proper login page when Switch is under concurrent TCP ping task. |
V |
V |
2. |
[eITS#220200724] GS1920-24HPv2 PoE ports do not power cycle when Switch performs the reboot process. |
V |
V |
Please refer to the Download Link for more details.
Jonas,
Hi, where can I get the patch please for ZON as usual the nebula update does not work although it tells me the patch is there0
Hi @PaulHunter,
Apology for the confusion, the first released was an urgent patch only for Zyxel GS1920-24HPv2 which fixed the bug below, so you won't be able to upgrade via Nebula and download the firmware for other GS1920.
Bug fixed:
#2 [eITS#220200724] GS1920-24HPv2 PoE ports do not power cycle when Switch performs the reboot process.
Please refer to the link in the post for other GS1920 firmware.
Jonas,Jonas,0 -
Links seem wrong... the text shows "Zyxel GS1920-24HPv2 - V4.70(ABMI.6)" but the actual link downloads GS1920-24HPv2_4.70(ABMI.5)C0.zip0
When I update to 470ABKZ6C0 via web interface, from Nebula interface, Nebula proposes another update, but revert the firmware to V4.70(ABKZ.5)0
Hi @Pbee,Links seem wrong... the text shows "Zyxel GS1920-24HPv2 - V4.70(ABMI.6)" but the actual link downloads GS1920-24HPv2_4.70(ABMI.5)C0.zipApology for the delay, we had already corrected the download link to patch 6.
Thanks for the advice.
Regards,
Jonas
Jonas,1 -
@Zyxel_Jonas No problem, found the error here while I already collected the right download over on the support pages.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
