IP table collision
DavidDu1130
Hi supporters,
I have two question:
Firstly, I am facing this too much on coreswitch XGS4600 when checking log 7 2022-03-20T20:42:13+07:00 IN switch: IP table collision : 192.168.x.x
Could you tell me what should I do to fix this matter.
Secondly, I want to show algorithm crc32l on my zyxel XGS4600 and change it to crc32u . But I dont know which command that help to show. Could you guys help me to do?
| Product Model: | XGS4600-32F |
| ZyNOS F/W Version: |
V4.70(ABBI.2) | 12/17/2021 |
Hi @DavidDu1130,
Welcome to Zyxel Community!
Please use the following command to display which hash you were using, like the figure below.XGS4600# show running-config
Note: "crc32l" is the default hash, so it won't display in the running-config.
In addition, you may use the "help" command for other hash algorithm options:XGS4600(config)# ip iptable hash help<br>
Hope it helps.
JonasJonas,0
Hi @DavidDu1130,
Hope it helps.
JonasJonas,0 -
Thanks Jonas,
I did it.1
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
