Bugs in last firmware
Hi, i have found some bugs in the last firmware update (V1.00(AAKO.9))
- Qos => class setup => add or edit => impossible to add IP address
- Qos => class setup => add or edit => the Classificaiton Order dropdown is not in sync with the real index of the rule (the sort is done like string, not as number)
- Qos => Monitor => Queue monitor vanish...
Hi, thx for the reply,
Yes I did it :
But :
Just see you put a subnet mask to 255.255.255.255, but mine is 255.255.255.0 ...
Also, if let it blank it's not working, in version 0.6 it was working in blank and 255.255.255.00 -
Hi @Dadv
The address field was defined that the “address” must be a signal IP address or a IP subnet address. So you need to enter the correct mask in the field.
If you entered mask as 255.255.255.0 then IP address should be 192.168.1.0 but not a IP address.
This behavior was changed in V1.00(AAKO.9).
OK understand for that, i'll change my mask for what i need.
Any clue about the other bug?0
- 415 Beta Program
- 2.4K Nebula
- 144 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.6K Security
- 238 USG FLEX H Series
- 267 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.3K Consumer Product
- 247 Service & License
- 384 News and Release
- 83 Security Advisories
- 29 Education Center
- 3.2K FAQ
- 71 Security Highlight
