XGS1250-12 LACP support ?
Для Крис !! Many thanks to you for your help! Can you really help me solve my question! Everything works pretty well now! I wish you success and all the best !!!0
XGS1250-12
Why am I not getting 2x1Gbps throughput speed between Synology NAS and a 5Gbps connected computer.
Hi @zigge89,
Welcome to Zyxel community!Link aggregation is to increase the available bandwidth between network devices.The switch will hash the incoming traffic based on MAC address and/or ip address to do load sharing. If there has two users are sending files to NAS, they can both have full throughput/bandwidth per link since switch will forward the packets to different link due to different source MAC address.However, one traffic flow goes one physical port and the maximum speed on one physical port is 1Gbps, so the maximum speed you see on the screen when sending the files will still be 1 Gbps.
And link aggregation also provide redundancy to prevent one link is down for some reason and you may keep using the NAS service.Zyxel Melen0 -
Is there a way to change the standardized groups made and individually select ports such as 1,2,3 and then port 9?
What's your purpose?
Link aggregation requires using the same data transmission rate. However, the data transmission rate of port 9 is different from ports 1-8. It might be hard to fulfill your wish.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
