NebulaFlex Switch GS1920v2 Series - V4.70 Patch 6 Firmware Release
Zyxel_Jonas
Zyxel_Jonas Posts: 313 image  Zyxel Employee
25 Answers First Comment Friend Collector Fifth Anniversary
edited June 2022 in Switch New Release
Zyxel Switch GS1920v2 Series
Release Note
February, 2022
Firmware Version on all models
Zyxel GS1920-48HPv2 - V4.70(ABMK.6)
Zyxel GS1920-48v2      - V4.70(ABMJ.6)
Zyxel GS1920-24HPv2 - V4.70(ABMI.6)
Zyxel GS1920-24v2      - V4.70(ABMH.6)
Zyxel GS1920-8HPv2   - V4.70(ABKZ.6)
New Feature and Enhancements
None
Bug fix
CLD=Cloud mode, STD=Standalone mode
No.
Bug fix
CLD
STD
1.
[eITS#210501222] Web GUI login page may encounter display error or problem to display proper login page when Switch is under concurrent TCP ping task.
 V
 V
2.
[eITS#220200724] GS1920-24HPv2 PoE ports do not power cycle when Switch performs the reboot process.
 V
 V
Please refer to the Download Link for more details.
Jonas,
  • PaulHunter
    PaulHunter Posts: 1 image  Freshman Member
    Fourth Anniversary
    Hi, where can I get the patch please for ZON as usual the nebula update does not work although it tells me the patch is there
  • Zyxel_Jonas
    edited March 2022
    Hi @PaulHunter,
    Apology for the confusion, the first released was an urgent patch only for Zyxel GS1920-24HPv2 which fixed the bug below, so you won't be able to upgrade via Nebula and download the firmware for other GS1920.
    Bug fixed:
    #2 [eITS#220200724] GS1920-24HPv2 PoE ports do not power cycle when Switch performs the reboot process.
    Please refer to the link in the post for other GS1920 firmware.
    Jonas,
    Jonas,
  • Pbee
    Pbee Posts: 32 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    Links seem wrong... the text shows "Zyxel GS1920-24HPv2 - V4.70(ABMI.6)" but the actual link downloads GS1920-24HPv2_4.70(ABMI.5)C0.zip
  • micheleschi
    micheleschi Posts: 1 image  Freshman Member
    When I update to 470ABKZ6C0 via web interface, from Nebula interface, Nebula proposes another update, but  revert the firmware to V4.70(ABKZ.5)
  • Zyxel_Jonas
    Hi @Pbee,
    Apology for the delay, we had already corrected the download link to patch 6.
    Thanks for the advice.
    Regards,
    Jonas
    Jonas,
  • Pbee
    @Zyxel_Jonas No problem, found the error here while I already collected the right download over on the support pages.
