Bugs in last firmware
Dadv
Dadv Posts: 8 image  Freshman Member
edited April 2021 in Security
Hi, i have found some bugs in the last firmware update (V1.00(AAKO.9))
- Qos => class setup => add or edit => impossible to add IP address
- Qos => class setup => add or edit => the
Classificaiton Order  dropdown is not in sync with the real index of the rule (the sort is done like string, not as number)
- Qos => Monitor => Queue monitor vanish...
  • CHS
    CHS Posts: 181 image  Master Member
    Hi @Dadv
    I just test it on my device, seems without problem.
    And dropdown view is correct.
    Did you select Ether type as IP(0x0800) when you adding the rule?
  • Dadv
    Hi, thx for the reply,
    Yes I did it :
    But :
  • Dadv
    edited July 2018
    Just see you put a subnet mask to 255.255.255.255, but mine is 255.255.255.0 ...
    Also, if let it blank it's not working, in version 0.6 it was working in blank and 255.255.255.0
  • Zyxel_Stanley
    Hi @Dadv
    The address field was defined that the “address” must be a signal IP address or a IP subnet address. So you need to enter the correct mask in the field.
    If you entered mask as 255.255.255.0 then IP address should be 192.168.1.0 but not a IP address.
    This behavior was changed in V1.00(AAKO.9).
  • Dadv
    OK understand for that, i'll change my mask for what i need.
    Any clue about the other bug?
