VPN BETWEEN ZYXEL ATP200 AND FRITZBOX! 7590
Good morning at all,
I'm trying to create an IPSec VPN Tunnel between an ATP200 and Fritzbox 7590 without success.
Does anyone did this VPN configurantion and can help me?
On the Fritzbox the error is:
Errore IKE 0x203D --> "phase 1 sa removed during negotiation"
The ATP Debug log is atached as "TESTVPN_LOG.txt"Thank you so much!
Thank you for your replyI've tryied with your suggestion but without success.The firewall log is atachedThose are the ATP's configurationsThis is the Fritzbox VPN Configuration:Thanks a lot!!!Best regardsLeandro0
If you can consider professional support...
Hi @Leandro85
You can have a try to change VPN connection setting.(Phase 2)
> Configure as remote Access(Server Role)
> Configure local policy as "192.168.0.0/24".0 -
Hi @Leandro85,
From the logs said, the VPN Phase 1 process is success but Phase 2 fail cause by proposal is mismatch.
Then I search google to check what algorithms Fritzbox can support.
The help say "Perfect Forward Security(PFS) is not support".
You can remove the Perfect Forward Security (PFS) setting in VPN Connection rule on ATP and try again.
Hi to all,
I have exact the same problems . I have a USG310 ServerSide and a Fritzbox as VPN-Client . Everything is configerued like in the Posts before.
The Fritzbox Log is :
VPN-Fehler: ATA154, IKE-Error 0x2026
Both gateway and connection do not enable PFS on Zyxel.
Disable for both Gateway and connection Key Group. Should report "none"IMVHO none of the three proposal should be used, I'd start with an AES128/SHA1. I'd disable also "narrowed".0
The Proposals are changed but the Gateway Key Group cannot be none . Only DH1,DH2,DH5,DH140
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
