GS2220 see how much Data pushed truth?
Username_is_reserved
Hi
I would like see somewhere if my GS2220-10 is fast enough to push out all Data who are get from and to an Port. Is there some way? Maybe I would need a bigger, faster to reduce the frame drops?
Hi @Username_is_reserved,
Since the GS2220-10 is Gigabit Ethernet switch, each ports have 1 Gigabit speed.
May you share your scenario or the speed you want to reach?
And may I know what do you mean to reduce the frame drops?Zyxel Melen0
And may I know what do you mean to reduce the frame drops?Zyxel Melen0 -
HiSorry for the late replay I found out how I can see how much Data get pushed truth.It seem my other parts of the Network sucks not the connection between both Switch.Thanks1
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
